Gauges ?
Elfster55
Frankfort IL
Wondering if I can replace the stock gauges in the cluster with actual oil pressure and temp rather than the stock ones?
charonblk07
Calgary, Ab
F1-A forged 349ci
That's a negative. It's one big circuit board back there and the entire module is about 1 1/2" thick, so no room to even squeeze one in between.
Elfster55
Elfster55
Frankfort IL
So I would have to run new gauges in the cubby he like I have seen and disconnect the other 2 right ?
charonblk07
Calgary, Ab
F1-A forged 349ci
Aside from pulling the needles off you can't get rid of them from the cluster, but you can install your own gauges, either in a pillar pod, steering colum pod, a mirror pod, or something in the dash. You have to leave the stock system intact so it can feed into to the PCM.
joshhhh
