Gear install list.
reefguy89
laurel de
hell yea that would be sweet. especailly powder coated to match your trucks color.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Got the tool in today!
Now just to let the guy know so we can schedule to do it on a weekend.
It aint easy.... bein' Easy ;)
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok I've got everything for the install, this week they well be installed also. Now i'm starting to get scared BC I remember a thread were the housing needed to be ground along with the pin. And also the spanner tool is still getting to me lol.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
what gears did you get again? Motives? your guy should know what to do if he runs into any clearance issues...05's didn't have housing issues, it was 06/07's I believe... also, if you do run into the pin issue, let him know that it is better to shave a little off the gear tooth to fit it as opposed to shaving pin.. (I spoke to a gear shop regarding this)... just have an angle/die grinder handy..
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Yea I wound up goin with motives. Thank you for the advise. Hopefully Friday we can start tearing everything apart.
ramin44s
4.7 v8
You doing a locker or a true trac aswell?
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
No a guy I work with needed new gears for his 37's and 4.7.... So traded me a pistol for them, and I picked up a set of motive 4.56's to throw in there lol
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
good luck, i just openned the rear yesterday so that I could replace the rear wheel bearings...it was easy with a slide hammer an bearing puller kit..
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Old thread but I've been having to put this off due to work.
Well the guy doin it said I might as well replace the outer bearings and seals to make the WHOLE differential new lol.
So someone make sure I've got everything Hahaha
Master install kit
Gears
spanner tool
New cover
Differential fluid
LSD fluid
New U joints
Outer axle bearings
Outer axle seals.....
Oh and $$$$ Hahaha
Sent from my VS920 4G
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
Makes sense, axle bearings an seals are a piece of cake to do with a bearing puller and slide hammer..
Master install kit
Gears
spanner tool
New cover
Differential fluid
LSD fluid
New U joints
Outer axle bearings
Oh and $$$$ Hahaha
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
i'm about ready to do my gears again as i about fried mine pullin a trailor at high speeds up a bunch of grades goin from Cali to Colorado.. my master kit is here, just gotta dig up the old 3.92's and install while saving for a new gear set..
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Dam sorry you gotta replace yours. Hopefully this guy can get me in his shop next weekend. I'm ready as can be to get this done!!
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I need ring gear bolts!!!
The guy told me he would prefer me buy brand new ring gear bolts.
Were can I get new ones?
I will be dropping the truck off with him next Friday for him to work on it all weekend.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I can get these for you. Last time I checked, I think these were about $4-$5 each. My differential supplier isnt open on the weekend, so I will call them Monday to check on this for you.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok that would be amazing!! If I order them Monday will I get them before Friday?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Definately. I will call them first thing Monday morning to make sure we get things rolling for you early.
