Gear oil
Iron Outlaw
I'm at 55000 miles and am going to change my own oil and differential fluid. How many quarts of differential fluid to I need to buy to do the front and back? Also cant decide if I want to go redline or amsoil. I'm going to do transmission fluid too at 60000.
2016 2500 4x4 with 6.4 hemi
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
9.25" AAM
2007.5 - 2012
SAE 75W-90 full synthetic GL-5 gear oil
2.45 qts
2013 - 2017
SAE 75W-85 full synthetic GL-5 gear oil
Magna 275
5.4 qts
Rear differential fluid
AAM 10.5"
2007.5 - 2012
2.65 qts
2013 - 2017
AAM 11.5"
2007.5 - 2012
3.8 - 4.50 qts
2013 - 2017
Found these on the Cummins Forum.
G. Mcpherson
Vancouver, Wa.
Also going to the Amsoil website you can get the amounts for each.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Amsoil gear oil is very good and so is Redline. Both will serve you well. Go to Amsoil's web site a plug in your truck info and it will give you your fluid capability. DONT forget the red thead lock.
Your gaskets should be in good shape but you never know. Would suck to get the diff plate off and have a bad gasket. They are expensive tho.
gville35
