Yeah, to me when I hit the shift up/down button it doesn't shift until it wants to, which could be instantly or a half mile
its not a shift button in that sense, meaning you cant hit the gear up button and expect it to shift. it doesnt work that way. what it does is limit your highest gear. if you select gear 6 it stays there until you select a higher gear or the truck feels it needs to downshift. obviously it has a built in fail safe so you cant lets say keep it in 2nd and blow the motor or trans. it will upshift in that type of scenario.
The only thing I don't like about this feature on my truck is that if I'm already cruising at speed and try to engage it, it always drops down to 2nd.
It takes a long time to activate from holding the "-" button down and when it does it starts scrolling down through the selectable gears until I release the button. In my opinion it should be (1) hold down to activate (2) release (3) press again + or - to select desired top gear (no long presses to scroll)...
