Gears are humming
ArDavid318
Oregon
Hey guys I just finished installing a new gears in my diff and im currently in the break in process. When doing my 20 minute highway runs I noticed it starts humming when I get into the 70mph range. I rebuilt my driveshaft as well with a new slip yoke but only took care of some vibration was having before.
I originally had the stock 3.55s and installed a set of nitro 4.10s with new hearings and seals. When installing them I set it all to spec and got a good pattern In my opinion. It is my first time regearing so I could have something wrong. Thanks for all the help guys!
Reactions: Mop
ArDavid318
ArDavid318
Oregon
Unfortunately no. I readjusted twice and installed a new set of gears but still had the same problem… the contact patters I came up with we’re looking pretty good to me but it still makes the humming noise at high speeds. Went through everything with a fine tooth comb when I changed the fluid after the 500 mile break in and things looked good. Might just be noisy gears. At least I hope the gears are just noisy.
DILLIGAF
Canadian Forces
Canada
Pattern looks good.
Try RL or Amsoil
Dean2
Near Edmonton
Are you sure it is gear hum and not your new driveshaft/U Joints causing the hum?
ArDavid318
ArDavid318
Oregon
I’m currently running Amsoil in it. It may be a slight bend in the driveshaft but I don’t recall it humming before the new gear install. I know things spin a fair bit faster now but even at uncomfortably high speeds with the old gears it was relatively quiet… darn thing has me stumped. I haven’t torn back into it yet, truthfully I was just going to let it live it’s life that way cause I don’t want to take it apart for the 5th time. Soon I will take my driveshaft in and get it checked. Next summer I might gain more ambition and throw a new set of bearings in and see if it changes anything.
