Gears!!!
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
So I noticed the other day that my pinion seal and one of my axle seals are leaking so i think its time for me to step up an put some 4.56 gears in the truck.
I just want to make sure i have all the parts
front 4.56 gears
master install kit
rear 4.56 gears
master install kit
axle bearing (most likely do both)
thanks
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Sounds like it as long as the master kit is just that. Does it include new axle seals as well? If you need preload and backlash specs, let me know.
Marx
Marx
ya shoot me those numbers, i think my buddy (who is certified) is going to do the work
is it bad to drive the truck with a leak?? do i just need to keep an eye on the fluid level??
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Front Pinion TTR - 15-25 in.lbs.
Backlash - .005-.007"
TTTR - 30-50 in. lbs.
Rear pinion TTR - 15-35 in. lbs.
Backlash - .005-.008"
TTTR - Not specified
You can drive it with the leak but make sure you keep a close eye on the fluid level.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Marx, You'll need a total of 4 x New Clips up front. 2 for the insides of the axles and 2 more for the 1/2 shafts and also 2 new rubber o-rings to keep out the water /salt (rusty splines/no good) once when you pop-em back into place (1/2 shafts that is).
Insist on a double lipped pinion seals as well. Good Luck your gonna love em!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Always good to have a reason for a new mod. Make sure you do the break in cycles.
casey1981
