Glove Box Emblem Removal
Dero
Tennessee
Bought this upper glove box but I have an express so I want to remove the rebel badge. Is it only glue holding the badge on?
Dean2
Near Edmonton
The only person who will ever notice it has the wrong badge is you. However, yes they are glue on. A hair dryer will heat it up enough to remove it. Be careful you don't direct to much heat at the material versus the badge. Personally I would leave it alone for fear of making a mess. Would be easier to cover it in my mind. That or swap this one for the correct badged door.
WileECoyote
Charlotte, NC
HEMI 5.7
I used a plastic panel remover tool and gently removed the emblem. Then used Goo Be Gone, a microfiber rag and some elbow grease. Then I washed with soapy water and it doesn't appear the Goo Be Gone stained.
It took a total of 10 minutes.
