Good Bilstein installer???
Ed F
Tryon, NC
Hey, guys. I’m in NC midway between Asheville and Greenville/Spartanburg, SC. I’m looking to find an installer for Bilstein 5100’s that has done them before and really knows how to install them. I’ve talked to a few shops already and I’m getting the ‘Nipper’ look from most guys. I know the washer placement is critical and if done wrong you find out the hard way down the line. Anybody with a decent garage who knows what they’re doing? I’m willing to get under the truck myself but I live on a mountain with a dirt road as my service bay. Thanks for any ideas...Ed
pacofortacos
Nothing hard about them. The washer just goes on first, nothing trick there either.
I will say this, the Bilstein 5100 strut has a much much smaller diameter rod than my stock struts did.
I also do not think they handle as well as my stock ones did.
The only reason I put them on was to lower my front a bit - I am seriously considering other options now. Even with them on, the front still sits at almost 36.5-37" high.
I was hoping to drop to a bit under 36".
Ed F
Ed F
Tryon, NC
Paco, you’re the first guy I’ve heard that put the 5100’s on to lower his truck. How did that work?
Ed F
Ed F
Tryon, NC
Paco, do you still have your stock struts around? I’m curious what the rod diameter is on those.
pacofortacos
LOL not as much as I had hoped, is did drop it a bit but I was hoping for more.
Ground to fender was over 37" stock, I think 37.5 if I remember correctly.
Yes I do have the stock shocks, I can try to measure the diameter tomorrow if I don't get beat up too much at work.
pacofortacos
My stock front strut rod diameter is 0.630" thick.
pacofortacos
That is what I was thinking going by memory.
I know I could see the rod bend and flex while installing the spring - with the spring compressors I used.
pacofortacos
Mind you, I have an Outdoorsman and the strut part numbers are not listed anywhere that I could find.
I do not know if they are a heavy duty option or just a standard issue part.
Ed F
Ed F
Tryon, NC
That’s scary.
Ed F
Ed F
Tryon, NC
I’m starting a 2500 mile round trip this weekend so any truck mods will go on the back burner for a bit. Thanks, Paco..
