Got A Check Gauge Light
Jack W
Only gauge not working was the oil gauge. Turn key off then back on and start engine and all is good again. Thoughts?
jws123
nj
either your oil pressure sensor failed or you have oil pressure issues usually that will rear its head at a hot idle.
diymirage
Banned
Check engine light didn't come on. Will there be a code for a check gauge light?
There are a ton of codes that get stored in the BCM without turning on a CEL
I would be more surprised if there isn't a code stored, then if there is
Steve58
