Got my Lockpick in!
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
Put my Lockpick in today. Aside from all the crawling around under the truck it really was a plug-and-play install. I took my time since I have a bad back, but an able-bodied person should be able to do this in 3-4 hours. Here's some pics of the highlights.
Rather than run the camera wiring separately I decided to run it inside the sheathing from the tailgate lock wiring I installed just 3 weeks ago. Would have been easier to do both together had I known back then I was getting this add-on.
This is the Bar-Cam mounted in place. The lens angle is adjustable, but not by much.
This is the harness from the electric tailgate actuator.
The harness runs along the driver-side frame rail. It will be zip-tied to the existing wiring harness.
This was the hardest part of my install, squeezing the camera wire into the split-loom harness from the electric tailgate lock already in place. My thumbs are killing me!
All done running the camera cable in the split-loom and secured to the existing wiring harness. Looks factory, eh?
I brought the camera cable in through the accelerator cable grommet by poking a small hole in it. Once I pushed the cable through I resealed it with some clear silicone.
The cab side of the grommet where the cable came through. More silicone just in case.
Removing the console and radio trim is pretty straight forward. If you use something to pry anything off a couple of pieces of tape will help prevent any scratches.
Once you have the shifter trim off grasp the bottom of the radio trim and pull gently. It should come off pretty easily.
Remove the connectors from the backside of the radio trim. No worry as to marking them because each can only fit where it came from. They all have little release tabs that have to be pressed while pulling. Be careful not to scratch anything as it is a bit awkward to get at.
The Lockpick's instructions are actually very good and there's no need for me to cover them here. All connectors fit only where they are supposed to go. There is plenty of room behind the radio trim to mount the Lockpick harness and main module. There is a lot of room under the shifter console, as well. After initializing and firt-run setup, I now have this on my display.
You can turn off the distance markings if you prefer, but it must be done before you close everything up. I like them, though. Not only does the backup cam come on automatically when you put the vehicle in reverse, you can access it at any time from the display screen. You can also switch camera views (in a multi-cam setup) and turn off the camera view with the left side steering wheel control. Haven't tried inputting a destination or watching a DVD while driving yet, but give me a few days.:
Miami Son
Miami Son
Banned
Port St. Lucie, FL
I got them both from Sonic Electronix. They had a "Make us an offer" deal going on the Lockpick and I got it for $180. The Bar-Cam was $78.99 and free shipping on both items. The dealer wants $350 for just the backup cam kit that has none of the features of the Lockpick and you have to pay for installation and ECU reprogramming for it to work.
Danimal77
Pontiac, IL
nice write-up...well done! Question? I got a 2012 ram a few weeks ago. It came with pretty much every factory option, except the back-up cam. Anyway, I told the salesman that I wanted a camera kit thrown in at no extra charge. He agreed to give me the camera kit, but said I would have to pay for install and activation. They quoted me $250ish for install plus another $85 for activation. I have the kit sitting out in the garage and plan to install it this weekend, if I get a chance.
My question is, will the lockpick be able to activate my new camera and save me the $85 dealership activation fee???? Thanks to anyone who might know.
Miami Son
Miami Son
Banned
Port St. Lucie, FL
I'm going to say no because the OEM camera will be connected via the factory wiring harness. The Lockpick will take the signal from that harness and unlock the features it provides, but that camera must be activated in the ECU first. In my case I had no OEM backup cam, so my cam plugs directly into the Lockpick thereby bypassing the ECU completely. The OEM cam does not use a standard RCA connection like these aftermarket cams use. You'd be better off selling your OEM setup on eBay, getting a Lockpick and paying someone to install it. You'll probably still come out cheaper and have all the added benefits that the OEM setup won't give you.
quietpeen
2021 TRX
Hellcat
very nice....where did you mount your camera?
Miami Son
Miami Son
Banned
Port St. Lucie, FL
I have the same exact setup! Nice job!
Quick question... how do you removed the lines on the screen? I didn't think you could.
The kit comes with 2 jumpers, one for the distance lines and the other for something else. There are two connectors in the main harness of the Lockpick where you plug the jumpers in to turn off the features. That's why I say you should do it before you close everything up because you can't do it via the menu.
Spanky1
6.7 diesel
Which Radio
1. Which radio do you have and does it have the navigation and Uconnect?
I have the basic radio but plan on getting a touchscreen from a wreck.
2. Will the RHR radio show on screen like yours or will it need the mirror display? I saw in another thread that a dealer told them it works thru the mirror display or is that just for the OEM camera?
Thanks
Miami Son
Miami Son
Banned
Port St. Lucie, FL
I have the 430N (RHB). It has nav and Uconnect.
You will still need to get it flashed by a dealer for it to work properly. Make sure you get one with a high-speed bus.
Thanks
I'm not familiar with the RHR and I don't know of any that use the rearview mirror for display. Not OEM ones, anyway. I would prefer to have both my rearview mirror and the display on the radio for backing up. Not one or the other.
