Governor??
ArmRippinToys
Anchorage, AK
I found the governor in my truck yesterday and decided 105mph is too slow, since theres no programmers or tunes available for the 2012's yet is there another way to get rid of it?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I'm not thinking so. I think you're stuck at 105 until a tuner comes out.
MADDOG
Living in a Firepit
6.4L HEMI
Nope...ya gotta get into the PCM to change it and that's the problem...no access yet due to the encryption.
man n black
Cummins
Brilliant YouTube link....only in Russia....hahahaa...
Ch
Sent from my DROID RAZR using Tapatalk 2
ArmRippinToys
ArmRippinToys
Anchorage, AK
No 105 isn't fast enough when the truck has more to give. I actually forgot about the flasher trick I did it on a gmc never tried it on the ram I guess on my trip back home I'll have to try it.
GhostRam94
Hunstville, Texas
2009 Laramie CC
I know it works on my 03 and I got to 108 in my dads 11 but I was kinda going on a slight downgrade so idk if it worked or if it was the hill but I think it worked, just let us know id it does for sure
garner
Harker Heights, TX
I can get up to around 108 in the new truck. And I could hit 108 in the R/T but it bucked when I hit 105 so I would slightly let off and then floor it again and it would go up to 108
jlb
MT
CTD
These trucks get to 105 pretty happily I think you could do 120+... I wonder if you pulled your rear speed sensor (the truck will throw an ABS code, but the ECU might think the speed is messed up) if the Gov would be disabled...
