Grill Mount replacement?
mpicc84
North Eastern, PA
Pardon my horrible google work, I'm normally pretty good at it.
Last night I was reinstalling my Grill with the wife when she decided to tighten the Drivers side screw down so hard she snapped the 10mm bolt that goes into the plastic mount. The bolt is still in the plastic mount, but the head is sheared off and its now not doing anything.
Can we order these mounts and Bolts? I tried google, tried Rock Auto, not sure what to do now.
yillbs
Good question, Call your local dealer and ask them. I find when I go to just get bolts, they just give me a handful, I always ask them to write it up so I can leave them a survey, they live by those things :)
mpicc84
mpicc84
North Eastern, PA
Good deal man. I'll give them a call. Hopefully this doesn't end up being a 100$ mount lol
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
you got you a wife that snaps off bolts huh??? better never **** that woman off, she might snap something off of you *****
Rampant
NJ
392 Hemi
Try ebay.
Sent from my SM-G920V using Tapatalk
Demon-HeMi
Houston
Haha the bolts are plastic, or I'd be very...very...worried!
your grill bolts are plastic? got any pix of them, mine on my 13 and my 14 were all metal bolts
mpicc84
mpicc84
North Eastern, PA
Yup. The Inside two are metal, and they screw into metal brackets. The outside two are plastic, and they screw into plastic mounts. I don't have a picture of them right now, and am about to go to work, But your sure yours are metal? They have a real big thread pattern for the plastic they screw into compared to the inside metal ones.
Demon-HeMi
Houston
im pretty sure mine are all metal, i do remember that they are a drastically different pattern though
Demon-HeMi
Houston
im about 90% certain mine are metal and so are my neighbors, his stripped the plastic hole out on his truck, ill double check mine if i remember when i get off of work
mpicc84
mpicc84
North Eastern, PA
I suppose that even with one missing it isn't the end of the world, I guess I'd just much rather have all four holding it in lol. There's only a little bit of play in it, but more then I'd like it to have.
Sent from my XT1585 using Tapatalk
yillbs
I just wen't out to check mine too, they are indeed plastic, I had no idea, it's only two of the four bolts though, but it's like , they are almost like fasteners, not bolts even. It's quite weird.
mpicc84
mpicc84
North Eastern, PA
They are a weird item indeed.
