Grill Shudders
Thank you all for the info. I may just pop out 1 or 2 and see the results. It's the easy way to start there.
There's 2 sides to the shutters,just make sure you leave 1 top and 1 bottom shutter in place on each side,the middle ones you can remove.Removing just 2 isn't gonna do much,either leave them alone or remove all the middle ones.
What grill do you have?
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
I seem to remember the consensus that all 180 aftermarket tstats are crap, are there any decent options?
I believe I had a Mr Gasket in my 2016 just like my 2022. Got them from moes-performance.com
I have had good luck with them.
pacofortacos
I went to put my shutters back in and can't find them Grrrrrr
When running an electric only fan, having a few removed helped keep temps stable. Currently running both fans again and wanted to see how it responded with all of the shutters in again. Hard to believe that I would have thrown them out, probably like everything else I will find them when I'm looking for something else - that I won't be able to find at that time. hahaha
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
If you lived near me, you could have my entire assy, less the motor. Just sitting in the garage gathering dust, along with the air intake filter box, intake air ducting, plastic engine cover, radiator fan shroud and clutch fan.
benjiRam
