2009 545rfe ram 2500 5.7 hemi
damit
NE
Been fighting issues with this pickup, old 545rfe lost od, and i replaced it with a used one with 160k on it, new atf4 oil, new filters, but 1 st gear wont pull its **** up and out of the hole. My torque converter slipage in 1st floored is only 312 rpm, seems on the lower side to me. My Cando scanner confirmed it is hitting all gears and i did have an evap code, which i fixed with a new hose, and a o2 lean code 2098 which will be fixed tomorrow. It just acts like my converter is too tight, let me know what to check next thank you!
jws123
nj
did you preform a re learn with a scantool? also 160k on a used trans is a massive gamble. Have you confirmed engine running good no misfires ect? Is it throwing any dtc's for the trans?
Burla
2010 Hemi Reg Cab 4x4
I guess you gave old trans as core? If not did you verify there was any clutch issue? Usually when 545 loses OD it is very fixable. Still have old trans in garage? Relearn for sure a must.
damit
damit
NE
No dtc i have an Cando c pro. I have not prefoemed a relearn, didnt know i had to. No miss fires typical lifter noise though
damit
damit
NE
I still have the old trans, it was only producing 3 psi for c2 clutch fill, but this low rpm take off was the same with it, but now the rest of the transmission shift better with replacement
Burla
Did you use old valve body on new trans?
damit
damit
NE
Thank you, im gonna go do a relearn
damit
damit
NE
How long should the quick relearn take? Seam like after i put in neutral it is taking 4 ever and my foot is getting sore holding the brake, no codes and yes itbis warmed up and park brake is set
Burla
Sometimes longer then others, but did you have a clock on it? 10 minutes give take.
BTW did you reuse torque converter?
damit
damit
NE
I used the one that came with the new to me trans. I waited over 15 but canceled, tried it 3 times. This is a cab and chasis 2500
