Mayor McCheese
I'm trying to diagnose a grinding noise that I experience when I start my truck after it has been sitting for a while, usually overnight. This happens almost every time I start the truck, regardless of the ambient temperature. From searching around in these forums, I'm thinking it might either be a bad bearing in the water pump, or the starter solenoid isn't disengaging. There doesn't seem to be any impact on performance, and it doesn't happen after the truck has been running and I shut if off and start it again.
Here is a video of the noise. You can hear it right as I star the truck, and then it kicks in and out a couple times over the usual ticking noise (broken exhaust manifold bolt head... typical Hemi stuff...)
