lpfm1990
- Mar 2, 2015
- 510
- 192
- Location
- Newfane NY
- 2016
- Cummins 6.7
So like the title says. Had my water pump recall done on my 2016 cummins about 2 weeks ago.... Got it home and checked the coolant level in the puke tank so I could keep an eye on it for if something was leaking. All has been fine and have put on about 700 miles or so since it was completed, heater/defrosters have been used also, now last night at 3am I go out to my truck to go home (had remote started it a few minutes prior to at least put some heat into the motor before driving) and soon as I open the door in greeted to the low coolant light on in the evic system... Wtf, popped the hood and checked before I left the parking lot at work (just had the hood open the day before to check the coolant and make sure it hadn't dropped, which it hasn't) on the way home it kept turning on and off till the motor got warmed up (obviously I know coolant expands) so... What gives, air lock???? The heat works great. And the water temp runs normal as it has for the past 29500 miles.... Where is the coolant sensor on these trucks? The resi is down from where it was before the pump (about an inch or so below the middle of the resi, if it is air lock, how do you purge the system on these (I really don't have time to get to the dealer for him to have my truck when I don't have a 2nd ride. And have a lot of stuff going on with cancer treatments for my father
