John Havron
I purchased a used 2015 Ram Express 2WD Standard Cab with 81,000 miles 1st part of April. I am totally happy. No engine ticks, everything works as it should. It came with an aftermarket Vararam cold air induction system. I have gotten as high as 27.1 mpg traveling country roads at 45-60 mph. Loving it. Anyone know of some aftermarket headlights that I can replace the standard projector headlights with that won’t leak or fog up? One is the old style with the black trim inside the headlight. This one is a friggin fishbowl. The other is the replacement headlight with the chrome bezel which works fine. Can’t find a matching replacement for under $300. Thanks. Also, while my iPhone is plugged into the charger in the console, with Bluetooth turned on I get no voice giving directions when I use the gps on my iPhone. Sometimes, I’ll get the first set of directions over the radio when I first set it up, then nothing either from the phone or the radio. Any ideas on a fix? Thanks
