Hard start
gowaffles
Mo.
2011 1500 ram w hemi became hard to start. If i turn ignition but wait a few seconds it starts easier. Once running it still runs like a champ. Confused.
CanuckRam1313
Ontario Canada
2023 Warlock
Have you done a battery/starter/alternator check to see how things are doing?
I just replaced the stock battery from my 19' a few weeks back because on cold start it was not as quick and snappy a start (if that makes sense...lol).
I did my research here on the forum and upsized to the H8 battery size (H7 is the stock battery and is 730cca I believe).
I put in a new Interstate H8 AGM battery and now have 900cca, and she fires up quick and snappy now.
I do have an upgraded audio system as well, so the bigger AGM battery helps keep the system happier too.
CamperMike
Peoria, IL
When you have trouble does it crank at normal speed but just not start? Or does it crank slow?
In cold places the capacity goes down eventhough the battery life extends. A lot of guys will run larger capacity batteries like h8 instead of h7. In theory it will extend the interval when you need to change the battery out. You need capacity for those cold crank amps.
jws123
nj
Could possibly be bleed back/faiing fuel pump before you crank turn key few times if it fires right up good indication fuel pump on its way out also of course check the battery ect like mentioned above.
joshhhh
