Header question
tommyboi87
houma louisiana
5.2 Magnum
I ordered a set of long tubes the other night and was wondering how hard they're gonna be to install on a stock mid pipe.
Merc225hp
NA
truck
gas
None of the stock stuff will work for you, or might be wrong as you are 2wd so not to sure on that.
rowdyram
magnum 5.9
I'm pretty sure the 2wd uses the same y-pipe. Merc is right. Ain't gonna fit
dapepper9
Iowa/Nebraska Border
5.9L V8
From whati found while i was looming at longtubes is that stock y pipe won't work and that you'll have front ds problems. Being as you're truck is 2wd pipe routing is the biggest problem.
If you for pacesetter what I've read about blow outs is that you need a different gasket and better bolts
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Ok so long story short, I'm gonna need a new y-pipe? And what do you mean front ds problems? I'm wanting to do true duals all the way back to the axle. So I'm probably looking at a shiny penny in other words.
rowdyram
magnum 5.9
Put your LTs on and buy some header mufflers...
Merc225hp
NA
truck
gas
If you are going true duals no need for a Y pipe is there, run them straight back. Or do as Rowdyram has suggested.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
No, I guess there isn't lol. Well ill be looking into tubing today. So I'll keep y'all posted with the outcome
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Ok, the best spot for an X pipe is closer to the headers right? Is so, these long tubes are going to be a pita!
Saleen5150
