Headlight bulbs 2008 ram 2500 6.7
tuckerjackson
Iowa
I put LEDS in the headlights and was having problems with them burning out or flickering on and off all the time. I learned I needed to added resistors but recently they like to flicker on and off still and sometimes when they flicker off they’ll stay off. What do I need to do? What’s bulbs and resistors should I get?
Nick@GotExhaust
Supporting Vendor
SC
You also need capacitors. resistors eliminate the bulb our error, capacitors eliminate the flicker. Morimoto makes a great harness that takes care of both. Not sure what LEDs you are using but I have seen some of the lower end ones found on Amazon and ebay not play friendly with a RAM no matter what.
