Headlight out
MFD98
Miami
Cummins 6.7
Hey guys, I recently switched out my low beam bulbs from the halogen to diode dynamic LED. My 2018 2500 came from factory with the projector housing. Since installed my passenger headlight is intermittent on and off. I have look on all the forums and have followed all the steps for programming it to LED with alpha obd, used a security bypass and still have not had any success. I have switched the bulbs from diver to passenger to see if the bulbs were the issue but the problem is the same, passenger side headlight is on and off. It does not flicker it will be on for a few minutes and then shut off while I am not having any issues with the driver headlight. If anyone could give me some insight
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
When you say that you followed all the steps in AlfaOBD, what exactly did you do?
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
turkeybird56
Central Texas
Possible bad wire, crimped, loose connection??? Socket, connector damage?
M
MFD98
Miami
Cummins 6.7
I turned on the cbc led low beam lamp present to yes and Vehconfig 3 high intensity discharge lamp to yes
M
MFD98
Miami
Cummins 6.7
Update, the on off happens with movement with the anti flicker harness, removed the anti flicker and connected the bulb straight to the wiring harness and it is working flawless
Carbary
