Headlight bulbs...What are you using?
BenchTest
Midwest
An update to my original post... just lost the 2nd one from the original install of Silverstar Sylvanias. Got 2 years and a week out of the passenger side, and now the driver side died at 2 years and +/- 2mos. Not a great track record for Sylvania.
jawzs2
Air Force
South Jersey
Wow, that's crazy for them to go out that quick. Unbelievably, the H9 Philips I put in mine back in 2017 are still going strong, (refer back to post #6). When I was looking into the upgrade, just about everything I read stated that because they burn hotter, they don't last near as long and be prepared to replace them often, which I was willing to do. I must have gotten really lucky with this set.
Of course, now that I said that - anyone want to start a pool to see who can guess how soon they'll now go out on me? :D
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
My ‘12 1500 Tradesman had OEM headlights and at first I strongly considered changing them to something else. I was driving, at night, back-and-forth twice weekly between DFW and back-roads CentTex, 5 hrs each way.
Did I mention twice weekly? For Ten years? At Night?
Eventually, I became accustomed to their generally only-fair, slightly yellow beams. Maybe it’s because 3+ hrs of those nighttime trips was on two-lane US 281 and not freeways. Not heavy I35 traffic. But saw lots of deer.
I carried new Sylvania replacement halogens in the Rambox ….and had read that you have to partially disassemble the fender to replace them…. Wasn’t looking forward to that job.
But…..Those OEM headlamps…. while not the brightest…. in 14 years and 220K miles…..never failed.
(That is the truck which was wrecked and I cleaned out the Ramboxes and moved all that 14 yrs of stored junk to the new Ramboxes, …when I found those Sylvania replacement lamps…that will not fit my new Ram.)
Anyone needing those never-needed “lucky-charm” lamps are welcome to them.
BenchTest
Midwest
On this '18 you have 2 bolts that are decently accessible so long as you have 9.5' of extension to reach one of them, don't mind inevitably breaking a mounting tab for said bolt, and enjoy accessing the "flap" inside the wheel well and mucking with the confounded slider lock assembly up inside said flap opening. Whomever designed such a DUMBA$$ contraption should be beaten about the head and neck with a dead turkey for 2 hours. I've reached that level of disgust for changing headlights on this truck... The biggest lesson learned is that I should have left the d a m n OEM bulbs installed and continued to be underwhelmed by their dull, yellow light in lieu of having this brighter/whiter "enhanced halogen" SHORT LIFE bulb.
star_deceiver
Airdrie, Alberta
3.6 Pentastar
LED in the reflector high beams, silver sucks ultras in the projector lows. LEDs in the lows clocked properly scattered everywhere and were completely useless in actual night driving in the darkness away from streetlights.
I will second BenchTest and say whatever engineer, desk jockey, penny pincher, on pencil pusher signed off on the headlight bulb change design and procedure deserves a swift kick in the nuts!
The Ultras light everything up nicely, are cheap, and seem to last about 2 years. I found what works for me and I’m not forking around. Set it and forget it.
PA Ram
Quakertown, PA
I used Sylvania Silver Star halogen bulbs for ages, back when there wasn't much to choose from besides HID or crap halogen.
During the last 10 or 12 years of use, they consistently survived about 14 months, or 2 months beyond warranty coverage.
Just like clockwork, or was it? I will never give Sylvania a penny of my money again.
This use was in my former '07 Tundra, which had horrible lighting, only used on weekends, but always with all lights on.
The Tundra double cab was larger than my Warlock, but apparently a shade of grey that was near invisible to other drivers. :rolleyes:
In my Warlock, I've used inexpensive Fahren and Auxito low-profile LED bulbs from Amazon, in factory projector housings.
The Fahrens in the low beams are about 2 years old, and Auxito in the high beams are a bit less.
They are fantastic! I rarely get flashed, and I can drive on rural highways at 50 mph with only the low beams on.
The Fahrens have a 3-year replacement warranty, and the company have been phenomenal to work with.
I don't recall the warranty on the Auxito, but it is at least 2 years. I will update when I find it.
If I were starting again, I would find used factory projector housings and Fahren LED bulbs, all the way.
One caveat: most LED bulbs sold during the past 2 years have become brighter every few months.
I have some concerns that they may all have become too bright and cause issues with oncoming traffic unless they are correctly aligned.
I would still choose Fahren LED, but might choose to direct them a bit lower than the standard positions.
This video refers to LED, but I'm convinced that it should apply to all headlights.
I have leds in my factory quad headlamps and they're bright,but aimed correctly,but every so often someone thinks I have brights on. I have no drop out so then I put highs on to show them. The quad headlamp does look like multiple lights when on. Trucks sit higher so your lights are gonna hit people's mirrors. I just got aftermarket projector headlights and bought led bulbs for them,but don't have them installed yet. I'm going to do that with my new steel front bumper when weather gets a little better. Expecting 12-24 inches of snow now through Monday. Factory leds on some cars now are crazy bright. Even sitting higher in my leveled truck on 34 inch tires I get blinded. I have fully led fogs that have multiple leds (non replaceable),but those will not be on once I change rhe bumper. New bumper has 2 led pods on each side. I already bought a harness to combine them to plug into factory fog connector so they come on with factory switch. Not running a separate switch. Only issue I came across with new headlights is I already swapped bulbs on one headlight to make sure they'd work. The low beam projector lines up at 3 and 9 no issues. The high beam isn't as accessible and I couldnt figure out how to get the bulb oriented at 3 and 9. Did see some tips and tricks online,but I put them in an outside shed before the storm so didn't try yet. I do snow removal for my brother in laws landscaping business so I'm gonna have a busy couple days. Not sure if all the projector housings have similar high beam setup,but it has a small rectangular reflector for the high beam and is off to the side of the compartment where as the low beam is easy access with the door off the back. If yours is similar do you have any tips? Saw I could resize the one tab to be able to turn it properly or put it in at a slight angle and turn it to 3 and 9 and should drop in to lock.
RamDiver
Marlborough, Ontario Canada
2021 DS
More line breaks, please. :cool:
I experimented a wee bit with clocking on the high beams. As far as I can determine, it doesn't make too much difference with the OE Projectors on my truck.
AFAIK, clocking is to reduce the scatter effect and the disturbance of oncoming traffic.
I don't use my high beams with oncoming traffic at any distance. I learned to drive in the late '70s, and the way I was taught, if you see an oncoming vehicle at any range short of several miles, drop your high beams. Maybe sooner, if the conditions warrant it. :cool:
PA Ram
Quakertown, PA
Same as far as high beams. I think everyone is taught that. Clocking at 3 and 9 mimics the regular bulbs for proper beam. Sorry about the line breaks, I'm on my phone and never intended to make the post that long.
I started driving in 1991 I believe (at least legally). Drove in different countries too while on the Navy. My headlights with fogs on are bright enough that I almost never use high beams. In fact I still have halogen bulbs in my quad high beam since I don't really use them. Just figured I'd go 100% led with the new headlights.
The lights are switchbacks with leds for turn and running lights as well as marker lights. I'm sure I can get the high beam figured out, just didn't get a chance to mess with it too much. Just figured if I had the bulbs in and ready would make the switch easier.
If I can't get it for some reason I'll leave the halogen in for highs since I won't really use it much. The tips I got should make it easier when I get a chance. Just figured asking here someone may have a better or more definitive answer.
Thanks
star_deceiver
Airdrie, Alberta
3.6 Pentastar
Of course since we have a headlight bulb thread… bulb dies…
DRL bulb went out in the Fiat yesterday. It lives right in front of the front wheel. Pull cover, twist cap, change bulb. Easy.
Headlights are right there. Twist cap, change bulb. The Italians crammed a lot of things in this tiny space but Tony still managed to make it easy.
PA Ram
Quakertown, PA
I miss when it was that easy on almost all cars and trucks. Sure would be nice to be able to reach back and take the cover off and pull the bulb.
MeatCurtains
US
2011 2500 tradesman, 2018 2500 tradesman, 2014 1500 Laramie
6.7 Cummins, 5.7 hemi
I got some sylvania long life bulb from rock auto for like 4 or 5 bucks. It lasted until I sold my 2011. Put the same one in the jeep after I had to replace the housing. It went 5 years and the jeep got sold with it.
KAKA
