Headlight swap
RudyGall
El Paso Tx
3.7L
So I've been trying to find out if it's possible to change a dual filament bulb headlight assembly for a single bulb headlight assembly. Haven't had any luck. Anybody try it or know anything else about it? Tia.
Wahrsuul
Central S.C.
Are you wanting to go from duals to quads? Or the other way 'round? Either way, for your '11, it's plug and play.
R
RudyGall
El Paso Tx
3.7L
Well, i have the ugly housings w/ the one big reflector. Easiest way I can put it. Lol. I wanna convert to the housing to where the high beams have their own bulb and same with the low beams. I'm just wondering if I need an additional harness or have to splice since the bulbs I have right now are dual beam and the housings I want are gonna use single beam.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Welcome to Ramforum. Check out retroshop.us. Jeremy is a vendor here and several of us have purchased headlights from him. I swapped my 2010 duals out for TYC projector replicas. Jeremy is very responsive via email and phone, is a super nice guy and will set you straight, even if you don't end up buying from him.
R
RudyGall
El Paso Tx
3.7L
Thanks. Appreciate the feedback from y'all. I checked him out and his stuff is exactly what I was wanting!
Wahrsuul
Central S.C.
You have what's called "duals" as in only two headlights, and you're wanting "quads". If you get headlights from an '09-'12 MY Ram, they'll be plug and play. One the back of the quads, there's a single plug. All of the additional wiring is internal to the lights.
