Headlights
BigPayne
HEMI 5.7L
Hey,
I have a 2015 Ram 1500 Big Horn with the standard headlights. I like the look of the projector headlights, so I am looking for any suggestions on aftermarket projectors and pictures if possible. Also if they would need an adapter as some I have seen would require one.
Thanks for any advice
Solid State
2011 Bighorn
If you're looking for the oem style projectors, TYC makes an affordable replacement. About half what the OEM run. And yes, you will need adapters. Check out retroshop. JJ is a vender on here, and has everything to set you up. Otherwise, take your pick from all the ebay lights, and you will still need some sort of canbus adapter to prevent errors. Hope that helps
iam_canadian22
northern ontario
Only need canbus adapters you you switch bulbs to hid's, if you get ebay projectors and keep halogen bulbs your good to go.
whatTHEmilone
Grand Forks, ND
2013 Ram 1500 Express 4x4
Hemi 5.7l
If you're going from the stock quads to factory projectors, you will need adapters. I just installed TYC projectors in my Ram and they look great. I found them for $200 on Craigslist, so try looking there. I know Retro Shop sells the adapters you need. I think they run about $125. I installed the dual resistor adapters.
12sportmc
NC
Damn that's a good deal on lights. I just dropped 400 on a set o TYCs from rock auto. Searched EBay and Craigslist forever with nothing as good as your deal. Great find
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I'm pretty sure you will need JJ's harness as on a quad headlight to OEM projector as you go to a one plug, and the resistors are needed for the LED turn signals.
