Hey folks, my 2016 Sport does not have the heated steering wheel or heated seats options. My question, does the steering wheel have the element inside, its just a matter of installing the button on dash? Ive been told all steering wheels do have the heating element inside? Also for my seats is there a viable option to install those elements and the button on cluster? I know how to strip the seats and reskin. Thanks in advance.
The *wiring* for the heated wheel is in the steering column, but most likely you will be missing the heated steering wheel itself along with the necessary clockspring. I believe you would also need the heated seat module as the steering wheel heat is controlled through there, and that usually only comes with heated seats.
Re-skinning the seats is an option, but the factory heating setup is fairly cost prohibitive. You'll be better off trying to find a good set of used, heated seats. They should come with the heated seat module as well, so its probably the best way even if it is more expensive than expected. If you are planning on upgrading to leather covers, etc then the existing seat cover condition isnt really important so it might be easier to find seats that satisfy your need.
BTW a bunch of people have suggested buying the special tool to remove the airbag. I dont know what tool it is or how much it is, but its been said that the tool makes it possible to get the airbag out in 30 seconds.
