Blend door working? If it's stuck in cold positing yout will not get heat.
Turn the key to on but don't start the truck. With the radio on 0 and fan speed on 1 but a vent selected, go from hot to cold and hot to cold with 1 second pause between each temp. Listen for blend in dash moving. Should just be a light buzz sound. If you don't hear anything it may be stuck. If you do hear it, continue moving the selector for a minute or 2 and exercise it a little. Sometimes they just gum up and need worked out.
Also make sure you don't have air in the lines. Jack passenger wheel up with engine running, rad cap off.
