Ben Murrie
Hey Folks,
So due to the help on this forum I've been able to fix several things with my 2002 RAM Quad Cab. I've also used the forum to try to troubleshoot an issue I'm still having, but to no luck. My heater won't blow hot. The A/C works fine, the blower works fine, and I can change the levels okay. It just doesn't get hot in any vent or any setting. The resistor is new, the heater core is getting hot and has been flushed, the blend door functions, the ignition switch is new. Is there any other possible solution I'm missing? Thanks for your help.
