Hello all !!
Fro78
Lancaster pa
Hi all
I have an 03 ram 1500 5.7 hemi
My question is can i add oil additives to the oil to make it not smoke. After driving for awhile then stop at a red light or stop sign then when i accelerate off you can see a cloud of smoke from the back. Im at 110,000 miles
MADDOG
Living in a Firepit
Welcome to RamForum.
Fast69Mopar
If you are seeing smoke after the engine warms up and after driving and sitting at a stop or a red light I suspect the valve seals, which are rubber, have gotten hard from age and heat cycles and are allowing oil past the seal and into the combustion Chambers.
It doesn't hurt to try an oil additive. Basically you want something to thicken up the oil like Lucas or STP.
If you have some tools and some basic mechanical knowledge, along with a Factory Service Manual, you could replace them yourself and save alot of time and money. The factory service manual is available for download in this forum under the DIY or Tech Forum.
Bloody_Knuckles
USN 81-86
Lebanon, TN
What color is the smoke? Bluish-white is oil getting past the rings. Black is caused by a too rich mixture.
Judy
Midwest
Good info- where are the service manuals found?
Bloody_Knuckles
USN 81-86
Lebanon, TN
Blueish smoke
Bluish smoke on acceleration is oil coming past the rings. Bluish smoke during deceleration is from oil being sucked past the valve seals. A ring job is the only real solution. While you have it disassembled, rebuild and replace everything.
