2005 ram 1500 stalling issue
ohbabyilovemoney
Harris County, TX, US
So i bought this truck about 2 months back and it would randomly stall on me whenever i came to a complete stop at a red light. It wouldn't stall while I was moving only when i came to a stop. The rpm would drop real low and try and catch it self but sometimes it couldnt and would stall. Usually, if I see the rpm try to drop, I can let off the brakes and catch it from stalling. Also when the rpm did drop the battery gauge would also drop slightly. so i did research and replaced the throttle body, that didn't fix it, replaced the MAP sensor, that didnt fix it either. I then replaced the crankshaft position sensor and the coolant temperature sensor, neither fixed my issue. I read it could be low transmition fluid, so i checked and the fluid is all good. Im kind of at a dead end here and dont know what else to try. Any help would be appreciated
jws123
nj
Try a idle air re learn with a scan tool. Also test your battery and alternator.
