Hello and help?
Brett Baker
Albany NY
I have a 2019 Rebel with the engine out and apart. I am installing a fresh long block. It came to me in rubbermaid bins. Is there a place i can find drawings or pics of placement of bolts or good pics of the engine complete and in thr truck? There are a lot of bolts and studs and knowing where the studs go before i put the engine in will save a lot time having to change thrm. I looked at some of the oem parts microfiches but they dont show much. Any hrlp would be greatly appreciated.
Thanks
Brett
gevans58
San Diego
Cummins 5.9L
Factory maintenance manuals - pdf available on dvd? I have the full manuals for my 04 on disk. Might try Geno’s?
B
Brett Baker
Albany NY
I have watched some vids but it is hard to see any detail in what i have seen.
I will be doing this install tomorrow so I will likely have to find a truck and take pics myself.
RamDiver
Marlborough, Ontario Canada
2021 DS
If you plan to take pictures as a guide, why not visit a local dealership or used truck lot?
RamDiver
2021 DS
That is likely what i will be doing, but I had hoped there was a diagram or two in existence
There are older PDF service manuals, but I'm not sure they will have the details you're looking for.
You can word-search these PDFs with a PC using 'Control F'.
Sometimes if you look up the Mopar part in question,they'll have pic's of the bolts that hold said parts on the engine.
About the only parts with studs or bolts that are confusing are the water pump / A/C compressor /exhaust manifolds
B
Brett Baker
Albany NY
Thanks, i will look at the components. there are also a bunch of m6 studs on the rocker covers and oil pan that hold harness etc and some m8? On the intake that do the same.
There's no studs on the intake,except the ones that hold the dress up cover on and the fuel rail,and personally throw that piece of crap cover in the garbage bin,the other studs on the valve cover and oilpan are pretty self explanatary on where they go.Look the harness over close,and use a tape measure and you should have no issues figuring out where the studs go
Steve58
