Hello from Battle Ground, Washington
EricKBattleGround
Battle Ground, WA
I'm perhaps a few years late in posting this - I've posted to this forum several times while looking for information to help in keeping my truck on the road.
I own a 2006 Ram 2500 Mega Cab 4x4 (diesel/manual trans) that I purchased new. The purchase decision was based on the phenomenal access to the rear seat area - important for my family, as one of my children has a physical disability, and I needed a vehicle that could tow, haul, and potentially be modified with a wheelchair lift. (That latter modification did not happen.) Prior to purchasing this truck, I was a GM addict - not any more!
I've put a lot of wrench time into the truck over the time I've owned it, though there are some repairs that I will send out to a shop. I've installed PowerSteps (2 times - first set failed in early 2024), a Jake Brake (Chrysler-branded Cummins kit), rebuilt the front axle with DynaTrac's Free Spin (manual locking front hub) kit, and done far too much electrical work on the truck.
I retired from Daimler Truck in 2024 - my last role was providing 3rd level technical support for electronic control systems. I was a jack-of-many-trades on the electrical side of things, and learned way more than I can ever share about harness design, electronics design, software design, user interfaces, and diagnostics (both DTCs and internal workings of the diagnostic tests that cause DTCs to be sent).
Eric
GB55
Maryland
Welcome!!
I'm sure that electrical knowledge will be well used around here
Dodge 1500 4X4
Rochester, NY
Welcome to the Ram forum, your knowledge will be a great asset to the forum, how about the short wire harnesses that's been plaguing the newer model's wow!!
