Hellwig 7960 or 7961???
t0ymach1n3
Oklahoma
5.7L???
Hey everyone!
Adding yet another question :)
Looking at pulling the trigger on either of the above end links but not sure with my Belltech 2/4 drop which would be the better option to go with the adjustability of the Hellwig rear sway bar. Searching here leads me to lots of lifted posts or lowered posts about 2 inch drops and going with the 7961. My mind tells me I need the shorter end links, being lowered 4 inches in the rear.
I'm going to keep looking, but can anyone confirm which would be the better choice? OR if they are using one or the other with a 4 inch drop in the back? Thanks everyone!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
My experience may be different than what you are seeking
I used the end links in the belltech kit. They worked fine, no need to purchase others.
As to the hellwig. Ran it about 2 weeks, switched it out to a road master 2500 rear sway bar
Better option in my opinion, as I could feel the truck overpower the hellwig in turns.
I'm 2 / 4
t0ymach1n3
t0ymach1n3
Oklahoma
5.7L???
Thanks for the response
Man, I was not really expecting hear that about the Hellwig setup lol. I'm less than an hour from going to Summit to go pick up the rear sway bar and figure out my end link situation because I put my drop on a few months back and I don't know if I got a pair with my kit or if I might have thrown them away. :oops:
I'm thinking the 6-8 inch adjustables (7960) as the stock end link and a belltech shorter end link (buddy had a set and gave me **** for possibly throwing mine away) are about in that range. More so than the 8-11 inch.
How hard you hitting turns to get that Hellwig to show out like that? Makes me wonder if I bought the right sway bar for my driving style
Bigskyroadglide
Moderator
I over drove the Hellwig daily. I drive my rig hard, nothing for me to take an 8 hour ride at more than speed limit.
It is my opinion the hellwig is ok as a stock replacement but in a performance application the 2500 bar is better suited. That why I went with the roadmaster.
I've had both and I like a flat steer circumstance better than the dip and roll in the back. The hellwig is on my 11 crew cab that I use for towing. It's also in the front hole of the bar, not in the middle as suggested by hellwig.
When I turn my wheels left or right at speed with the road master my truck responds with minimal dip and roll. It handles very flat like I want.
My opinion you may never feel the difference.
Even the stock rear bar off a 2500 is better then the Helwig bar.If you can find a wrecked 2500 i'd grab the rear swaybar off it,if you can get it cheap.
t0ymach1n3
t0ymach1n3
Oklahoma
5.7L???
I went ahead with the purchase, being that I have an Express with no tow package, I had to get something back there asap!
I'm searching for a 2500 as we speak. I couldn't believe how much thicker it is compared to the Hellwig. I will say that the Hellwig is for sure better than nothing. It's a bit wet out tonight but I could already tell a difference in the ride.
Suln
California
I'm 2 / 4
So i have a 2022 1500 quad cab 4x2, will a 2500 road master be a direct bolt on? Also what should i be searching for to find more options? Thanks
Bigskyroadglide
Moderator
Is the 22 a classic (old. Body style)or 5th gen(new) body style?
broteinshake
New York
So the 2500 road master bar is stiffer than the hellwig bar in the stiffest setting? Or is the road master bar thicker but hollow whereas the hellwig bar is thinner but not hollow?
Bigskyroadglide
Moderator
The roadmaster bar is thicker and solid. It does not have multiple settings like the hellwig.
You can also try a 2500 bar if you have a salvage yard in your area
