Detroitfd
- Oct 28, 2013
- 24
- 0
- 2005
- Cummins 5.9 diesel
my 05 Cummins hesitated a little and got worse over a couple hours of driving. Pulled codes w my Smarty and got accelerator pedal sensor low circuit. Cleared and drove more and got same code plus the APPS low code.
Luckily found a campground and got there w the trailer. Part will be in tomorrow.
It looks like there’s just 2 bolts holding it, so should be an easy swap. Anything else I need to do after swapping?
I did read about resetting the APPS after replacing the pedal assembly.
Any suggestions?
Any suggestions?
