Help adjusting headlights
darkknight
5.7 V8 Hemi
I have tyc projector headlights. While adjusting the projector i may have cranked it up to high and i heard a pop and the headlight popped down. Now it will will go down and not up. Any ideas?
1500ram12
5.9L Cummins
The adjuster sits on a ball and socket. Most likely it popped out. You will have to pull the light out and remove the back cover. Look inside the light where the adjuster goes through the housing. If you should be able to see if it's out. Or just wiggle the projector. If it goes up and down than you know that is your problem. Just take a screw driver and lift up on the projector mount underneath where the socket is. It will pop back in
Sent from my VS985 4G using Tapatalk
RHeller
usa
your raising your headlights with a 4" lift?????
D
darkknight
5.7 V8 Hemi
I was playing around with the adjustments after installing the tyc projectors and it just popped. Will try the steps above hopefully i can fix it.
D
darkknight
5.7 V8 Hemi
So i fixed the adjuster that was not fun. However now it seems as though the light needs to be adjusted horizontal. Can't get a straight line. Any advice?
RHeller
usa
there is no adjustment for that except turning the actual projector. your output looks just like mine does
D
darkknight
5.7 V8 Hemi
I've seen pictures of owners with straight lines when aiming. I would think there has to be a way to fix it?
RHeller
usa
that step is suppose to be there. It is so you dont blind oncoming traffic.
bisdak
@darkknight, i have exact problem with the vertical adjuster. do you mind sharing how did you fix it? did you also find a way to adjust the horizontal throw?
