Help Chattering transmission
Monica B Shick
Norwalk, CA
04 Ram 1500 5.7 Hemi Magnum chattering transmission
I'm not a Gearhead by any means but I took to a so called mechanic who couldn't tell me anything didn't find the problem and didn't fix anything I'm not afraid to look under the hood or even tear apart an engine or a transmission if I have to any ideas would sure appreciate it
MADDOG
Living in a Firepit
So how about a little more information on the chattering.
Does it do it only when cold or does it do it all the time?
Does it chatter during acceleration? How about when just cruising down the highway?
Does it shift properly?
When was the last time you had the fluid changed? How many miles on your truck at present?
Monica B Shick
Monica B Shick
Norwalk, CA
It doesn't cold hot it doesn't matter usually I notice it when I'm making a left hand turn on acceleration doesn't usually do it when I'm on a straight away usually when I'm going from a dead stop making it turn warm or cold I have a 121000 miles on it and now today the engine won't start all I get is a clicking wont turn over won't crank I don't know I'm throwing my hands up in the air right now
MADDOG
Living in a Firepit
the second problem sounds like a dead battery or failed starter. Have your battery tested.
the first problem sounds like it is time to service your transmission and differential.
Monica B Shick
Monica B Shick
Norwalk, CA
thank you for your quick response can you recommend a good transmission shop ,
thank you for your quick response can you recom number battery is good I tested it with the the lights and with the air flow in the cab I hit the the starter to see if it was just not engaging and maybe it was a stuck how hard is it to change the starter and are there any how to manuals that you can recommend I do appreciate your assistance have a great day and I look forward to your responses
i'm going to do it myself...
Monica B Shick
Monica B Shick
Norwalk, CA
Please excuse the typos I'm better with a
wrench than I am with this phone
HemiLonestar
Navy Badge Coast Guard
MD
Apparently lol, holy run on sentences Batman. If I'm understanding you right, the chattering is only turns; that sounds like a front CV axle going. Check the boot to see if it's torn. The start issue could be the battery, or it may be just a dirty hot lead to the starter (I had this issue). Do you have at least 12v in the battery?
