Help finding quick strut
neoginn
Houston, TX
3.6 pentastar
I bought the repair manual for the Ram 1500. And I feel somewhat confident / crazy enough to undertake changing the squeaking strut on my own. But I cant for the life of me find a suitable quick strut, i am not trying lift the truck.
TL:DR; I got a ram 1500 2013 v6 crew cab 4x4 big horn, can I get some help finding a few options for quick struts?
N
neoginn
Houston, TX
3.6 pentastar
Moog vs Gabriel? I never heard of these guys which one should i get?
smithwessn
Moog has been around forever and well known for producing bushings. I've never heard of Gabriel but I'm sure someone here has.
JB1
Houston, Texas
Get the MOOG
5% off code for rockauto
9967503894631789
stimpy433
IOWA
Both are quality brands but i’d get the Moog between the two.... but that just cuz i’ve always used Moog when possible.
N
neoginn
Houston, TX
3.6 pentastar
Ok im getting the Moog. Is there anything else i should get to change these out?
smithwessn
Get some penetrating oil and start soaking the bolt that runs through the control arm about a week before you are ready to replace the struts. I hear they are known to seize up. Lol.
Other than that, a complete strut assembly is pretty easy to swap out.
N
neoginn
Houston, TX
3.6 pentastar
The code worked and i got the part coming in a few days. Do you think there any tutorials out there for a diyer like me? I got the repair manual. but any other resources i could look at?
smithwessn
I'd check you tube. There has got to be a video of someone replacing a strut on a ram in there somewhere.
savage_46
Alaska
6.4 swapped
Unbolt the upper ball joint. Use a long pry bar against the lower strut mount to get it in & out. Unbolt the top of the sway bar end link to pry the control arm down further if needed.
Other than that, pretty straight forward.
joshhhh
