help-flooded my truck
bu2je
first tme i post here. Ok i drove in to some really deep water and it died so i tryed to restart it it crank but would not start so i let it seat for about ten mins tryed to start but now im just geting a click sound from the starter. Pulled all the plugs most wher wet, pull off the intake had about a inch of water and put a new starter on and still dont crank over all i get is click, click, click. What do i do now 2005 dodge 1500 5.7
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Hope you did not hydro lock your truck that will be a big bill
reefguy89
laurel de
im no mechanic but it sounds like you hydrolocked it. maybe pull off the valve covers and heads then try to manually turn the crank.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would pull the spark plugs and turn the engine over by hand. It sounds like it is hydrolocked. Hopefully nothing bent/broken. If you find water in the cylinders blow it out, and like I said, try turning it by hand. there have been a few folks on here who have done this. Good luck,
HemiBabe
DFW
Yeah..... that doesn't sound good.... why would you drive it into deep water in the first place lol? Good luck with figurin it out....
quietpeen
2021 TRX
Hellcat
I hope that isn't your only vehicle
pavester
texas
you just witnessed firsthand what its like to kill a truck
Redtruck-VA
Virginia
Jeremy, any update?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im late to the party here but deff a hydrolock. Luckly its not to hard to rebuild, or drop 3k on a stroker.
Redtruck-VA
Virginia
i've seen a couple hydrolock threads and is there anything to learn from folks who have gotten into this situation? Such as, does this only happen with stock OEM air boxes? Basically what can be done to prevent water from being sucked into the engine? I use a standard K&N CAI cone filter that sits high in the engine compartment over the fender. It is shielded on three sides and there is no way water can collect in it. I'm not concerned with Red as she doesn't go off road, but I am curious as what actually happens.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Its been all styles of intakes that have caused a hydrolock due to deep water. Only style I cant honestly say I have seen or heard of is Vararam. I think anything you go deep enough in and stay in there will cause an issue. When hunting I have only gone as high as my bumper. Most of the time the rods will get bent, cant say to many have actualy cracked a piston. Pulling the motors on these are actualy not bad, if its a 4x4 you have to fight the damn front diff/trans/motor mount bar. Thats the only ruff thing to work around.
Redtruck-VA
Virginia
Well, lets hope Jeremy reports back that his motor turns over ok. I hate seeing engines tore up like this. When mine goes I want dented hood and cut tires....
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Me to Greg im hoping for the best on it for him.
98sporttj
west chester Ohio
2006 QCSB 4X4
4.7L
pull the plugs and crank it over... blow the water out... re install plugs and start it up... then change all fluids... the motor shouldnt be the only thing you should be concerned about... esp a trans get water in that and ****... have hydro locked a jeep a few times, pulled plugs blew out the water by crankin it over and fired her rite up
4.7Ram5.7Rango
Lynchburg, VA
4.7 Flex
Im speaking from personal experience..... its locked bro. I locked up my old furd a couple years ago in a bigass mud/water hole. Needless to say a wave of water OVER the cab is definately no good, lol.
This ^ is why I havent wheeled my Ram hardly, lol.
Edit: What do ya'll mean by cranking the motor over by hand? How would one go about doing that? We tried pulling my truck forward while it was in reverse, I guess to spin it back and pump any water out, but all efforts were to no avail. Yanked the plugs..... they were brown :(
Reticle918
