95360magnum
- May 31, 2013
- 53
- 1
- 1995
- 5.9 magnum
I have a 95 dodge ram with a 360, it stranded me today, was driving up a really rough dirt road suspension bottomed out, and the battery tray snapped off laying the battery over onto the belt (which i found later) the belt cut the case of the battery, which sprayed fluid everywhere and ripped a ground out of somewhere (assuming a body ground) anyway, the truck still ran and drove fine, parked at the lake unloaded, got back in, moved it parked again, when i came back it wouldnt start, which is when i found the battery damage. I need advice on what all to check for no start. Fuel pump runs, all lights, turns over, but wont start, doesnt even try to fire, could it be the coil? Or the ground that broke? No plugs or wires loose anywhere, cranks like usual but no start. Is there a way to check the coil? Please any advice is appreciated, need to be able to get to workv
sent from the interwebs powered by beer and gasoline
