Help needed
jawzs2
Air Force
South Jersey
This site will give you the pinouts and a diagram of the connector
MODULE-BODY CONTROL C6/F​
Full Repair Kit: 68440523AB​
No terminal repair kits have been identified.
End View​
/connectors/13850165_13850160_13850161.gif
Isometric View​
/connectors/13850165_13850160_13850161_iso.gif
Removal Tools​
A specific removal tool has not been identified.
Pin Information​
CavCircuitGaugeColorFunction
1P9100.80BG/GNFRONT DRIVER DOOR UNLOCK
2P7770.80GN/DBDOOR LOCK RELAY CONTROL
3P2920.80VT/GNPASSENGER DOORS UNLOCK RELAY CONTROL
5L3000.80GN/WHHIGH BEAM FEED
6L140.80WH/BGCARGO LAMP DRIVER
7M50.80WH/GNFOOTWELL LAMP FEED FT LT
9G750.80VTDRIVER DOOR AJAR SWITCH SENSE
11D1460.35WHCAN IHS (-)
12D1450.35WH/GNCAN IHS (+)
23G740.80VT/WHPASSENGER DOOR AJAR SWITCH SENSE
25L5510.80BG/BNLEFT FRONT LIGHTING FAULT SENSE
26L260.50BG/VTCARGO LAMP SWITCH SIGNAL
27L5630.50WH/GYLEFT REAR LIGHTING FAULT SENSE
28L5520.80BG/OGRIGHT FRONT LIGHTING FAULT SENSE
31L5620.50WH/BGRIGHT REAR LIGHTING FAULT SENSE
32L730.80WH/DBLEFT REAR PARK LAMP DRIVER
35P8070.50GN/BUINVERTER SWITCH SIGNAL
36L6550.80WH/OGLEFT REAR TURN SIGNAL CONTROL
39L510.80WH/DGBRAKE LAMP SWITCH OUTPUT
40L520.80WHLEFT STOP LAMP DRIVER
41L150.80WH/BGLEFT BACKUP LAMP DRIVER
Jeepwalker
WI
2012 Reg Cab, 4x4
Just google it, or watch some Y/T videos 'swapping/changing/replacing Ram TIPM'.
