Asked a few questions on here before and I have yet to introduce myself. Jason from Alabama. I have a low mileage 2015 Ram 1500 Express Quad Cab 4wd. So far I have upgraded the cluster, performed RA4 conversion (Thanks Grimm), added auto dimming rear view mirror with Bluetooth microphones, ceiling console, remote start with proper hood latch and pinning the #11 in C1, push button start and passive entry. Everything I have done works properly EXCEPT passive entry. I used a kit I purchased from a seller on marketplace that uses genuine Mopar parts and a 17-18 RF Module. The issue I am having is I can disconnect battery and the passive entry works correctly with both key fobs but once truck is started (remote start or regular start), the passive entry will not work again until I disconnect battery and repeat. I followed Jimmy's install post and have triple checked all the settings in Alpha that I am supposed to change. I have triple checked my pins in the plugs. I have also verified passive entry is checked in the RA4. Anyone have any ideas and/or advice on what to check or do?
Thanks Guys
