Help on best options!!!!
crazzywolfie
under the truck
usually the 360's had 4 barrel carbs and not 2 barrels so it most likely just has a 318
movinalong
movinalong
greenwood ms
I'm ok w a 318. Well the deal is mad I'm goin to get it as soon as I can. One more noob question I see it's just a 3 speed auto. So how hard is it to swap it to an overdrive transmission?
crazzywolfie
under the truck
swapping to a overdrive transmission should be fairly easy as long as the truck is not 4x4. i think with 4x4 trucks you might have to also swap transfer cases. you would also have to get drive shaft shortened no matter which way you go.
B-g-K
Upstate NY
Ecodiesel
That's a carb for sure if you ask me. I'd bring a new battery, and clean all the connections with a wire brush quick. Check the oil, maybe even change it quick before you go, give it a little starting fluid or fresh gas in it and see if she'll cooperate.
movinalong
movinalong
greenwood ms
Kinda what I was thinking but if the truck truck was supposed to be fuel injected. Wouldn't it be better to go back with it. I'd be willing to bet any 318 injection would work or no?
crazzywolfie
under the truck
if someone has already converted to carb properly that is most likely the best way to keep it unless you can find the TBI parts because they would not be cheap. if anything you might want to look for someone parting out a 92 or 93 with the mpfi 318. a mpfi 318 are nice and usually already bolted to a overdrive transmission.
movinalong
movinalong
greenwood ms
Nice thanks for all the help with this I'm sure I'll have tons more questions before it's done with.
