help on part
jonesboys
1999 ram 1500 bought it with a leveling kit in the front going to a 5 inch rough country lift i need the part that the spacer took the place of in the top of the shock tower it sets on top of the coil spring and has the three studs to bolt the top of the shock tower to rough country does not have and the dealers here cant locate a part number any help please thanks kenny
reddot
Wolf Point, MT
5.9 cummins
Just the stud ring? Or did they ditch the isolator ring also? Top Gun Customz has extended stud rings. Not sure if they have them listed on the site but email them and they will send them out, or call.
quietpeen
2021 TRX
Hellcat
welcome To RF. I moved this to the lifted section
Okiespaniel
Work, Shop, Computer
magnum, 5.9
LMC truck carries the bolt rings and rubber isolators.
Your dealer probably doesn't list the 2nd gen #'s anymore but third gen 2500's use the same parts.
The rubber isolator is a bit different looking but Ram claims they interchange.
Please post up when you get everything together and let us know how it went.
Raadz
