HELP!!! Replacing Hub...
DeputyDipShizz
Pennsylvania
Attempting to replace a hub...At the point where I need to pull the axle shaft and there doesn't seem to be enough room. Have it pulled off of the spline at the pumpkin but can't get enough to pull it off all the way. Am I missing something here or way off? Doing the drivers side on a 2006 ram 4x4 5.7 with 4 wheel abs. Any help would be greatly appreciated...ASAP would be even better!
***Please excuse any and all typos as my large thumbs cannot fit the keyboard correctly***
Nickxxxr
Near Reading, PA
Need more info how far into axle are you??? What u take off so far
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk 2
DeputyDipShizz
DeputyDipShizz
Pennsylvania
At this point I have the axle nut off...Shouldn't the axle shaft pull off if the spline right by the pumpkin
DeputyDipShizz
DeputyDipShizz
Pennsylvania
uploadfromtaptalk1335661498001.jpg that's from the front of the truck, pumpkin on the left hub assembly toward the right
DeputyDipShizz
DeputyDipShizz
Pennsylvania
Well I gave up for the night, but any help would be greatly appreciated...I also need a new splash guard (the circular metal piece behind the rotor since its all rusted) and Auto Zone doesn't seem to carry or order them.
DeputyDipShizz
DeputyDipShizz
Pennsylvania
You cannot get to them without removing the axle shaft. Stuck at that point
DeputyDipShizz
DeputyDipShizz
Pennsylvania
Believe me, I tried lol
alnelson14
Cummins
Jack up underneath the spindle. This will make the A arms more of a 90 degree angle from the center section, making the distance between the two farther.
DeputyDipShizz
DeputyDipShizz
Pennsylvania
I'll give that a shot tomorrow...did tonight to an extent but I was about shot for the night, work 9 at my full time job Friday day and went into my part time job for a 24 hour shift and got home tonight at 6 and went.to it...Only having 2 hours of sleep in 48hrs didn't help matters...But they did give me the wrong hub assembly so I brought the connector with so I can match it it to the right one. Googled my problem and found a similar situation with an 06 and the correct part number was listed. Thanks for the help fellas of there are any more ideas let me know!
DeputyDipShizz
DeputyDipShizz
Pennsylvania
Well went back today and got it all off without doing anything else...Guess I just needed sleep and patience to think lol, Tuesday the part for a in hopefully it goes well
LB3711
Trumbull, CT
3.6L V6
damn too bad I wasn't down that area this weekend. I would have helped
DeputyDipShizz
DeputyDipShizz
Pennsylvania
Jobs not over yet haha
sofakingsuite18
I am having the exact same problem...I can't get the damn thing off. I've been prying and pulling and it's so close but I just can't get it to clear. Any idea what made the difference for you????
