John.nails
- Sep 24, 2013
- 3
- 0
- 1998
- 5.9
My truck bogs down when at idle and hisses until it eventually dies. And then revs up and stays at 1700rpms while sitting at a red light. And sometimes dies while turning. Figured it was a sensor issue and have changed the TPS, IAC, and, due to my mechanics suggestion, taken apart the intake manifold, replaced all gaskets, decarbonized and then reassembled. Still running like ****. It's to the point where I have no choice but to sell it. I've changed out the downstream O2 sensor, and switched out the ECM. My mechanic has gone through the vehicle and says that there are no bad grounds and its not an electrical problem. He's also changed out the crank sensor. Any suggestions?
