Help with belt squeal.
rick-rock
Lincoln, California
So I just add the electric fan and the ATI pulley about two weeks ago on my 13, 5.7 RCSB. When the truck is started in the morning I get what sounds like belt squeal for about a minute or two and then dissipates. If I drive a short distance(10mi) turn it off then start back up, I don't have any squeals.
The belt I'm using is Master pro with the same part# as gates K060716,72-1/8" OC. There is tension on the belt maybe even a little more than the factory belt(I figure because its new).
Is this just a cheap belt and need to try another? Has anyone else had this problem? Very annoying.
JasonK94Z
Anderson, SC
Buy a Goodyear Gatorback belt. It will never slip.
GoldDot
There is a tsb for this due misaligned pulleys. Believe it or not mopar offers a different belt for the fix.
R
rick-rock
Lincoln, California
Being I have the under drive pulley, I don't think that will work.
I am going to order a Goodyear belt and try that.
Kotta390
I can't find a gator back belt for the stock setup anywhere? Does anyone have a part number for it for a 2014 ram?
GoldDot
Took a look around and doesn't seem like they offer one for the stock set up.
alphaprojects
