Help with coolant leak
kdkretzer
Suffolk, Va
Started noticing a coolant leak in the driveway and its leaking from above the rear part of the engine on driver side where i can’t see the leak. It leaks down and puddles above the starter then runs down around the transmission bell housing. Anyone had a leak in this location and know where it might be coming from?
2017 with the 5.7 Hemi
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
It could be leaking from somewhere else and running to that spot before draining off onto the driveway. Liquid will often migrate to a lower point before draining off. The source of a leak is often not directly above the puddle. Thinking logically about this, I would check all hoses, hose attachment points, and water pump weep hole. Also check around the intake manifold. Are you sure it's coolant?
