Help with hids please!!
paulycoppola5
Schenectady, NY
Hey guys,
So today I got the HID kit in that I ordered from JJ. Never really even opened the hood on this truck yet. Figured I've installed numerous HID's and have done everything from a full drag car build on a mustang to a transmission swap in a 2002 z06 vette to headers and procharger on a camaro. Basically I am fully confident in my skills to put in some lightbulbs and mount a box.
Anyways...THIS SUCKS! Whoever designed this setup needs to be kicked square in the balls. At the risk of sounding like an idiot I spent about 45 minutes trying to get my headlight assemblies out and I roid raged all over my driveway and gave up. I am at the point where I have no interest in even having them anymore and want to return them (already sent JJ a message to return them to him). I have to be totally missing something and there is a super easy way to do this, I hope. Otherwise no HID's for me I could care less at this point not worth the aggrivation.
Can anyone give me a decent write up, tips on doing this install, point me in the direction of another thread on this, ANYTHING? If so I'd greatly appreciate it, if not, its in the mail these things go..
Thanks in advance guys! And please don't be harsh on the comments as I am sure many of you with half an ounce of patience probably breezed through this install in the past, but I was close to smashing anything in sight today.:suicide:
Mod's if this should be under "exterior" feel free to move it and sorry for posting in the wrong section!
res1551cue
Scott AFB, IL
Maybe this will help.
I realize there are threads on this subject before. In fact I got motivated to do this project because silverbullet05 started a thread here http://www.ramforum.com/f41/sylvania-silverstars-installed-2012-ram-1500-a-21689/ but (call me dumb) I got elbows into the truck and still didn't know what I was looking at. I decided to take some photos and make a this detailed thread so my wife can do this mod while I'm at work (...like that will ever happen ppsssst!).
My project today was to switch my stock bulbs out for Sylvania Silverstars & Ultras. Here are the replacement bulbs you'll need.
Here are the tools you'll need for the entire job.
1) Remove the shoud. Probably the only thing I didn't take pics of is the radiator shroud/cover you'll have to remove. There are 6 plastic push clips that have to be pulled out to remove the shroud. I didn't stick the screwdriver under to pry it up because I didn't want to scratch the paint. I'm **** like that. I lifted the shroud on either side of the clip using both hands and pulled up until the push clips finally popped out.
2) Remove the grill. There are plenty of people that will tell you that they have no trouble with practice getting the headlight housing out without removing the grill. When I started to remove the headlight housing, the top bolt opened into the grill rear so I decided to take it out. There are 4 10mm bolts that have to be removed on the top of the grill. Once they are removed, there are two silver clips that hold the bottom of the grill in place. In order to release them you need to slightly lean the top of the grill (while standing in front of the grill facing the truck) toward you. There are two spring clips at the bottom (one on each side of the grill) that have to be popped out. That is all that is holding the grill. These are the pics of the bolts to remove.
These are the points on the truck where the items to be removed are. The two points at the bottom are where the spring clips that hold the bottom of the grill are.
This is the retainer and spring clip that you are removing. This photo is of the bottom of the grill. Keep in mind while you are removing the grill that the spring clip is under the silver plastic retainer. All you will see when you look down between the radiator and grill is the top of that silver clip.
This is where the spring clip is locked into. The hole just above it is where the plastic retainer is shoved into.
3) Remove the headlight housing. There are only two 10mm bolts and a plastic clip that you need to remove the headlight housing.
A) Here are the two 10mm bolts. As you can see in the pic I already removed the upper bolt.
B) You need to remove a sliding plastic retainer clip that you need to access from an access panel within the wheel well. I turned my tire to the left as far as it would go to give me the most room to work. Likewise, I turned the passenger side as far to the right as it would go. This photo is of the driver side so yu could see where the access panel is.
Here it is closer. To open the access panel, you need to remove the same type of push clip that held the radiator shroud/cover. It's at the bottom of the access panel.
Once you have it open, you'll have to reach in and feel around for a plastic slide retainer. The easiest way to find it is to feel your way along the fender, through a hole. Reach a bit higher and you will feel this SQUARE plastic piece you need. Once you find it, pull it down to release the headlamp housing. It looks like this and you can see my hand reaching into the access panel to give you an idea of how far you need to reach.
This is what is locked behind the slide plate. If you don't get to it the headlamp housing won't come out.
The headlamp housing is ready to be removed. It's much harder to pull it straight out. The easiest way to remove it is to grap the housing from from both sides (so it doesn't fall and scratch your bumper) then swing side near the bolts (center of the truck) toward you (in the direction of the front of the truck) and swing it (the center part) out toward the side of the truck. The opposite side still in it's place. As it swings out you will feel it release and come out easliy into your hands. As it comes out you will see the headlamp wires still holding onto the housing. The wires the farthest to the side of the truck are the amber parking lamps. Now is the time to change these if they are old so you don't have to go through this again in two weeks when it burns out. In this image you can see the smaller hole on the left with the light green color in it. That is where the amber parking lamp goes. Rotate it, to remove it.
The next wire that will be holding on, the last one left, is the headlamp power source. If anyone is installing HID replacement kit, this is the power source you will need to connect to the ballast. To seperate both clips apart you will need the flat head screw driver. First, slide the red retainer back away from the black pug. That is at the top of this image.
Next, reach in with the screwdriver and lift the green tab while pulling the plugs apart. Try not to pull too hard on the wires. We don't want them to come out without the plug.
Now the housing should be free. Place it on a soft cloth to avoid scratches while you work.
There are two dust covers that need to be rotated and removed. That will expose the both bubs (high and low beams) to be changed. Referring back to this image, the lower bulb is the high beam (replacement bulb 9005) and the One on top is the low beam, you can see it in this image with the green color (replacement bulb H11). The bulbs need to be rotated to be removed from the housing and the retainer clips released to pull the bulb from the plug for exchanging.
To reinstall, follow these directions in reverse order.
I exchanged my bulbs with the Sylvania brand "Silverstar Ultra" because I wanted a brighter bulb. I live on a dark dirt road away from the city so I needed the extra light. I took some before and after photos. They are explained below.
The first pictures are the fog lamps alone. Top before (stock bulbs) and bottom after (Sylvania Silverstar).
Second set is of the low beam headlight and fog lamps combined. Top before (stock bulbs) below after (Sylvania Silverstar Ultra).
Third set is of the high beam. Top before (stock bulbs) and below after (Sylvania Silverstar Ultra). By the way, the dot on the right side of the road is a stop sign lol.
If you want to know the difference of the stock bulb to an HID (high intensity discharge) lamp replacement, the HID's are 300% brighter than stock.
To replace the fog lamps, all you need to do is look under the truck and behind the bumper. This is what you'll see.
This image is taken from the driver side of the truck looking over to the passanger side. You can see the back of the fog lamp in white.
Exchange the bulbs by rotating the bulb to remove from the housing and removing the retainer clip to exchange the bulb. Then replace it (replacement bulb 9145).
This image show the bulb removed from the housing.
If this post helped one person out it was worth my time. Thanks for reading it!
res1551cue
Scott AFB, IL
Now I didn't do this write up. It was Birddog that did it.
TexasRammer
College Station, TX
Lol dude I get that feeling all the time... in fact it happened to me today lol. Looks like Dustin found it for you. those 4th gen headlights definitely look like a ***** to take out
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I'm about to tackle this this next week on the rooftop of a parking garage. Lol. So we'll see how that goes. Whenever I get pissed at something, I find it easier to go relax, watch TV, and browse the internet until I calm down, and then when I go back out and try again, it always seems 100x easier.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I love that write up. Thanks for posting that!
Yeah, the 4thies are fun......but let me know what ya decide to do bud!
P
paulycoppola5
Schenectady, NY
Had a really busy weekend since Thursday between OT at work and plans with the wife and was at a wedding yesterday... Haven't had the chance to log into here or look at emails/pm's etc.. but wow what an awesome write up. Thanks so much! Definitley makes me reconsider sending my HID's back now. Going to give it some thought tonight and make a decision tomorrow since I will be off from work Wednesday Thursday and Friday, and I have pretty much nothing planned until Friday night.
MADDOG
Living in a Firepit
I say go with it. I know it can be a huge aggravation but in the end, the HID setup is wayyy better than the stock halogen setup.
Just make sure you turn everything on before ya button it up to make sure it all works right.
P
paulycoppola5
Schenectady, NY
Always test before you put it back together!! LOL I've learned that one the hard way a few times!
MADDOG
Living in a Firepit
P
paulycoppola5
Schenectady, NY
Such a kick in the nuts isn't it?? I think I may keep them and tackle the project on Wednesday.
Texasez
Dallas tx
I'm in the middle of doing all my lights hid including fogs. I was going to write up one for the whole set up when I get done. I haven't found a dummies guide to hids yet. I trashed my headlights trying to open them so JJ is going to save my a** with a new set. Once I get JJ to make sure I'm not putting bad info out there ill post one up.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I'll nab some pics for you in a sec here Mac ;)
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I can swap my headlights out now in about 15 minutes...have it done pat :)
Came Across The Same Problem When I Installed Mine... Pain In The Ass But Then I Figured It Out, Those Pictures Will Help A Lot, But You Do Not Need To Take The Whole Grill Out To Get The Head Light Assembly Out As Long As You Have A Long Enough Socket Extension To Reach The Lower Nut. Then It's All The Same As Those Photo's With Going Through The Wheel Well Access Panel. When You Push On The White Clip And Push The Head Light Out ... Be Careful You'll Feel Like You're Going To Break It But You Won't.
Vancouver604
Hemi 5.7L V8
Don't feel to bad It took me about 45 minutes today to figure out how to remove my front grill.
