help with trans tune....
Bad Habit
Land O Lakes
Modded 4.7l
okay to start off look at my mods and what i have done, i also have a schedule set up on my truck but dont think its good enough, i need help building a good schedule. first off i have a 4.7l 04 with 4.56 gears, havent found a schedule that has those yet, i did find one that was a 04 4.7l and i kinda used his to go off from, but its not suffice. i still have to stab if you will to downshift and i have what i call flat spots which as i ease onto it it seems i need to stab it then, i know i can do better but im not sure what to do, i guess i could just up my values a little on each but not sure if i will screw it up....heres what i have so far excuse the fact its not on a spreadsheet i suck at them....and im sure its basically what i just typed up.....if someone can help please do so or point me in the right direction......
1 up
tp%..........s/c.......... stock
0.............14.59.........13.73
8.235 ........18.02........ 13.73
16.47........ 24.89........ 19.74
44.70........ 54.07........ 38.62
44.70........54.07........ 48.92
100........55.79........ 48.92
2 up
tp%........s/c........ stock
0 ........22.31........19.74
8.235........30.04........ 19.74
17.25........ 46.35........33.47
44.70........73.82........ 65.23
44.70........ 84.12........ 91.84
100 ........ 99.57........ 91.84
2 pup
tp%........sc ........ stock
0........ 25.75........ 22.31
6.667........29.18 ........22.31
25.88........57.51........48.92
44.70........87.55........75.53
44.70........87.55........102.1
100........104.7 ........102.1
3 up
tp%........sc........stock
0 ........44.63........30.90
8.235........51.50........ 30.90
17.25........63.52........ 48.07
28.23........83.26........62.66
38.03........91.84........98.71
38.03........127.9........133
100 ........127.9........133
4 up
0........59.23........53.22
10.98........74.68 ........53.22
24.70 ........88.41........80.69
28.23........99.57........102.1
28.23........140.7........151.0
100........140.7........151.0
5dn
0........ 55.79........49.78
21.56 ........73.82........49.78
31.37........85.84........66.95
38.03........94.42........92.70
43.13........136.40........145
100........136.40........145
4dn
0........ 41.20........ 27.46
19.21........ 54.07........ 27.46
37.25........75.53........48.07
47.05........84.12........70.38
52.15........89.27........84.98
59.60........96.14........84.98
59.60........118.4........109.8
100........118.4........109.8
3dn
0 ........19.74 ........12.01
35.68 ........39.48........12.01
35.68........39.48........24.89
52.15........ 60.94........44.63
54.51........64.38........57.51
100........93.56........57.51
2p dn
tp%........ sc........stock
59.60........0 ........0
59.60........82.40........84.98
100........100.4 ........84.98
2dn
3.529........11.15 ........12.01
52.15........ 26.61........12.01
52.15........30.90........20.60
59.60........34.33........20.06
59.60........40.34........37.77
100........50.64........37.77
20% trq mgmnt
Vendor
Florissant, MO
2x 5.7L & 6.2L
do you have your excel sheet for this? That would make it much easier to play with.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Make one - its so much easier to look at them with those purdy graphs.
B
Bad Habit
Land O Lakes
Modded 4.7l
honestly i dont know how....ask me about physics or electromechanical stuff and i can do that if i was taught i prolly could do this as well...
If you want I can plug your values into my excel sheet and graph it for you. Graphing it is really the only way to dial it in.
B
Bad Habit
Land O Lakes
Modded 4.7l
scott on dt is helping me out but thanks teach, i wish i knew how to graph it out and know where the tweakin needs to be....
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
just plug the numbers in, the graph will update itself.
