Helppp!!!!
jsmith180601
I disconnected my battery to clean the terminals. After I put the leads back on the battery I checked to make sure things were working as they should. Well without the key in the ignition neither the headlights or fog lights come on when the switch is turned. When the key is turned to on (and when started) the headlights,all the tail lamps(except back up lights), dash lights come on. High beams don't work floodlights don't work and wipers don't work. Turn signals also don't work.
Like I said all I did was unscrew the bolt to remove the battery terminals toclean them...
Please if anyone knows or can help I'd love that
Sent from my HTC One VX using Tapatalk 2
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Check all of the fuses. You could have popped a couple putting the terminals back on. Only thing I can think of......
Sent from my VS920 4G
J
jsmith180601
Nope my father in-law checked all the the fuses and relays.
Were leaning towards the computer
Hurley91
5.7L
Will it start? It sounds like it's just a fuse.
HolyRamBatman
Deep in the Heart of Texas
Sounds like a fuse. BUT it could also be a connection somewhere. Sometimes a weak connection will stay together until it loses power and then it's broken.
Kinda like changing a bad light bulb. When you turn it the filament will make contact and work. Turn the switch off and it wont work.
Thinking about it check your grounds around you battery. There should be a bunch that come into one spot to make up. Good luck
J
jsmith180601
It was the fcm (front control module) that fried
Sent from my GT-P3113 using Tapatalk 2
Raadz
