Commander 06
Ok so I'm curious to see if a stock hemi throttle body will fit on a 4.7L the stock hemi throttle body is 80mm and the 4.7L stock intake manifold opening is 80mm so would not need to port my stock throttle body if the stock hemi TB would bolt up.. the stock 4.7 TB is 73mm so would most likely need a custom tune.. which my truck is already tuned and my tuner is custom tune able so not to much of an issue there dose anyone have a stock hemi TB they can get the bolt pattern off of.. I know both TB use the same stock bolt .. not sure about the electric connector if same or not
